Use statistics to help you monitor OSPF performance on a VLAN. You can also graph statistics for all OSPF packets.
- Select VLANs.
- Select a VLAN.
- Select IP.
- Select the OSPF tab.
- Select Graph.
- Select one or more values.
- Select the type of graph.
OSPF Field Descriptions
Use the data in the following table to use the OSPF tab.
| Name | Description |
| VersionMismatches | Indicates the number of version mismatches received by this interface. |
| AreaMismatches | Indicates the number of area mismatches received by this interface. |
| AuthTypeMismatches | Indicates the number of AuthType mismatches received by this interface. |
| AuthFailures | Indicates the number of authentication failures. |
| NetMaskMistmatches | Indicates the number of net mask mismatches received by this interface. |
| HelloIntervalMismatches | Indicates the number of hello interval mismatches received by this interface. |
| DeadIntervalMismatches | Indicates the number of dead interval mismatches received by this interface. |
| OptionMismatches | Indicates the number of options mismatches received by this interface. |
| RxHellos | Indicates the number of hello packets received by this interface. |
| RxDBDescrs | Indicates the number of database descriptor packets received by this interface. |
| RxLSUpdates | Indicate the number of Link state update packets received by this interface. |
| RxLsReqs | Indicates the number of Link state request packets received by this interface. |
| RxLSAcks | Indicates the number of Link state acknowledge packets received by this interface. |
| TxHellos | Indicates the number of hello packets transmitted by this interface. |
| TxDBDescrs | Indicates the number of database descriptor packets transmitted by this interface. |
| TxLSUpdates | Indicate the number of Link state update packets transmitted by this interface. |
| TxLSReqs | Indicates the number of Link state request packets transmitted by this interface. |
| TxLSAcks | Indicates the number of Link state acknowledge packets transmitted by this interface. |
